Spark Plugs
  • Ken in Cairns
    Ken in Cairns
    Just a quick question on plugs.
    Stick to the stock HD ones for a basically stock 103 ??
    Or go for the iridium ones ?
    Want to change em out before my big cross country trip, and carry the old ones as spares.
  • Ken in Cairns
    Ken in Cairns
    Yep OK, what I thought.
    Had mine out, and the shoulders are starting to round off, hence my question.
    I'll just bung in some new standard HD ones ( 7 bucks each) and keep the others as spares.
    I know I shouldn't need em, just like I hope I don't need the tire plugger kit, but better safe than sorry out were I'm heading, not that you can do much on these new fangled things if they die.
  • Ken in Cairns
    Ken in Cairns
    Must be the Screaming Eagle ones to get 62k out of em Paul :)
    Seriously thanks for the reply's, I'm sure I actually don't NEED to change em, as they should go to at least double what they have on them, but fresh plugs and a good used set as a spare will make me feel better :)
    Maybe he's not such a bright spark after all PB.
  • Ken in Cairns
    Ken in Cairns
    Didn't mean to cause offence PB.
    Sorry if I did.
    Ken
    You are all good Ken, it is SRD we are revving up for not reading PBs post properly!! He obviously had a brain fade, which is ok on these forums. Gives us the chance to pay each other out.
  • FONTANA302
    FONTANA302
    This was a back to back test HD plugs vs NGK Iridium after optimising tune a couple of years ago, 3 pulls each set of plugs.  Iridium is the higher HP & torque, compared to standard.  This was my 103, Andrews 50H 4 deg advanced, S&S Turbo Muffleres & S&S Intake.  I am running the Iridium's on this & my 120R, no ion/knock sensor issues.  Had the knockometer installed (additional accoustic sensors for ping/detonation sensing) when tuned the 120R for additional verification.
  • Ken in Cairns
    Ken in Cairns
    Phew, all good then :)
    0.5 isn't much really as stated, looks like stock ones, unless I decide I want the gold coated ones for the "Bling factor" LOL
    Guys
    PS Off to work for 5 or so weeks so I'll be quite for a bit.
    Cheers again.
    Ken
    I'm glad this topic came up actually. It reminded me to get some new plugs for the next service I need to do before an upcoming trip. Thanks lads.
