big vibration after changing engine mounts
  • garlo
    garlo
    Hi Guys,
    I recently changed my front and rear engine mount on my '08 FXD, and since riding it again, I have notice a lot more vibration. Did the front while bike was as upright and level as possible. When I fitted the mounts there was a fair gap between mount plates and the engine mounting bolt sleeves, so I just torqued them up to the set tension, which brought everything together. Any suggestions, please?
  • garlo
    garlo
    If it's in regards to the filing down of the rubber to open a gap between the top of the rubber, etc,... there is more than ample clearance. But if it isn't, then I'll google away. Cheers for the feedback =-]
  • garlo
    garlo
    Cheers mate
  • 78gold
    78gold
    I have an 06 Lowrider and made up a couple of spacers, Ireckon itvibrates less than before, can even use my side mirrors now.
    I have some pics if it helps, may have even posted on here before.
  • garlo
    garlo
    Thanks for the help guys. Looking to source some steel locally to make the shims up. A fella put up a blog regarding bolt sizes, drill sizes, etc regarding this type of mount... so I'm looking at doing the same. (Funny how they tell you your mounts are shot and you need new ones coz it will vibrate less... and when you change 'em, you could pretty much mix paint on them)
  • Sparra
    Sparra
    I used washers for the spacers,worked ok...
  • Sparra
    Sparra
    double post...
