ape hanger cables
ape hanger cables
Fat Tom
Hi all , I am looking at putting ape hangers on my 07 Fatboy. I wish to buy a second hand set with cables. Can anyone advise me of which cables from different bikes and years that can be used.
thanks Tom
All HD 1986 big twin and up are the same , if your fitting 16" as a exsample you would just plus 6" cables, buy new ones .zodiac brand are good quality and price
DocGreen
I thought the idle/throttle cables changed in the way they attach to the hand controls from 96 on? Used Magnum braided cables when I put mini apes on my old fatboy - good quality.
Good luck
DocGreen
Fat Tom
Cant help but be a little careful, that little bit you save by buying a second hand set can quickly end up costing you more if you dont know this stuff. Just to confirm, the clutch and throttle cables are the same on all twin cam A and B motors whether it is dyna or softail ?
Yes
