Rocker cover replacement, How?
Kingchops
The space between the rocker covers and the tank on newer Sporty's is extremely tight. Hard to imagine you would be able to remove the rockers without removing the tank. I would remove the tank and the seat. There is an electrical cover behind the rear cylinder which can also be removed. That should make disconnecting the knock sensor easier. I have the tech manual for 2014 Sportsters I'll see if I can find the procedure and post it.
Kingchops
If anyone else is after the 2014 Sportster Service manual, send me a PM.
shadowarrior
Use imgur
AlHD48
nice i am going to do that too
noctm
nvm
