fuel inlet valve
fuel inlet valve
KurtFatty
Hi guys, just a quick one, replacing the plastic Fuel Inlet Valve on my stock CV carb on my evo. Discovered a slight crack and slow fuel leak.
Is the below stock?
Thanks.
pretty much. Stock is plastic, BUT its very common to use the brass ones as they never crack like you have just had.
Put it in the freezer overnight to cool it and shrink it a little and then some locktite on it as you press fit it in. Make sure you get the angle / direction of the outlet facing the right way before you press fir it because once they are on they are pretty much impossible to turn.
KurtFatty
This ol' chestnut...
