Online: Humbug
Polishing wheels
  • Nutty
    Nutty
    2011 FLHR wheels with 1000s of holes...what's the go to polish them. They've never been cleaned since new, you can imagine.
    Is there a small polisher that can do the job?
    Any advice welcomed.
  • Ken in Cairns
    Ken in Cairns
    Multi speed Dermal with a flex drive for the tool and Autosol polish, is what I'm thinking :)
    Good Luck
  • Baloffski
    Baloffski
    Sorry to take away from you ken. But you do mean dremel, with autosol? I think K K K Ken meant it's is all in the product, like S100 and such.. Excellent polishing ability.
    Can I move to the winning side , only over queensland winter??Please..
  • Ken in Cairns
    Ken in Cairns
    Maybe that's what he meant Baloffski, I just took the "is there a small polisher" bit as he was after a non manual way to do it.
    Yes I meant dremel , as in small electrical die type grinder, fitted with the polishing attachments.
    The variable speed ones allow you to have it rotating fat a wide range of speeds and the remote flexible drive allows the tool heads into smaller spaces.
    Sure you can "Visit" over winter, lots do ")
  • Ken in Cairns
    Ken in Cairns
    LOL true that, and they bloody drive to slow on the Port Douglas road, O look at the pretty view while I do bloody 40 KM/hr, and then speed up on the only passing lane for 30 KM, grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
