Lifting jack
Lifting jack
Shambells
Hi guys I have a 2004 dyna super glide and was wondering if any of you lifted the dyna on a lifting Jack if so do you use lifting adapters .
brucefxdl
i have a simillar lift and bolted 3 spacers where needed [ dyna with the frame plate at r/h/r, 19x 50 rhs ] and it works fine,when i lift the wifes intruder i just add a block at the 4th point ,all good .
Ranga
I have an 07 Superglide and use a similar jack. I think I got mine from Repco. In any event I haven't needed spacers yet. I have only needed to use it a few times.
