Online: John.R
Lowers for a 2014 Deluxe
  • MarkC
    MarkC
    Hi guys & Gals new to this so let's see how it goes
    I'm looking for options for fork mounted lowers for a 2014 Deluxe as Harley says the ones they have don't fit the Deluxe due to the bullet Indicators that are fitted.
    Any help would be fantastic as I'm at a lose on where to go to find something
  • MarkC
    MarkC
    yes wind deflectors that mount on the forks.
    Im told that they will help with the head buffering that happens when I have the Wind Screen on, only use it for long rides.
    Any suggestions would be great and if you got photos or can point me in the right direction it would help.
  • graz
    graz
    Definitely work a treat when you have a windscreen on Markc. Had them on last three bikes.
  • steelo
    steelo
    Folks.
    Been thinking of fitting some fork deflectors to my 2014 Ultra with fairing lowers. Called into HH today. All of the listed stainless lowers are designated not to be fitted to models fitted with such fairing lowers. Kuraykyn didn't have anything. There's a crowd called street-glide.com that has a version but it only shows the earlier indicator/driving lights as fitted.  Anyone had any luck?
    AND FYI got a quote on plain Harley heated grips from HH today. Nearly $300 for the grips, Almost $400 to fit. Have seen a good instructional video on fitting though
  • steelo
    steelo
    Thanks for info CB and PB.
    Sorry to hijack thread
    CB, do you have a thread or pictures on what you did to trim some to fit?
    Regards
  • MarkC
    MarkC
    Thanks guys
    The Standard Harley windflectors I'm told won't fit the deluxe due to the bullet indicators.
    Looks close when you look at the photos, so I was going to get them but the dealer said no refund or in store credit if they don't fit.
    I was going to take chance if they would give credit as I wonted some other stuff just don't won't to blow $150
    Looks like I might have to risk the $150 and see what mess I can make, thanks CB
  • steelo
    steelo
    Thanks CB. They look good (contrary to what others say about the lowers)
  • MarkC
    MarkC
    Thanks CB
    Where do they mount From?
  • MarkC
    MarkC
    Thansk Gaz
    I have looked at the HD wind deflectors. The book says they don't fit the dealer is either way on it.
    Woundering how CB are mount, are they on the screen mounts
  • MarkC
    MarkC
    Looks like I found some made to suit a Delux
    http://www.jescustomaccents.com/WindDeflectors-FLSTN-Fat-Boy-Slim-Chrome-05-P-SftDluxe-FatBoy-Slim-WD-Chrome.htm;jsessionid=55F69675321E8DE5DE0E2E2AD933B073.p3plqscsfapp005
