Online: John.R
Boging paint work help
  • bloodog
    bloodog
    Have just had a mate mig the holes closed, I now am going to bog over the mig welding
    Any tips on how, type of bog etc would be cool
    Thanks bloodog
  • Far Canal
    Far Canal
    Are you getting someone else to paint the guard?.
    If so you might as well let them do the bog work as they will have done it before. Also they would probably prefer to do it themself if they are worth their salt. It is only a small job looking at that guard.
    If you are going to paint it yourself then using bog is pretty easy. You basically mix it up to the 50/1 ratio or what ever the product says on the can, lay it on with a putty knife or even a butter knife so that it sits proud of the eventual shape you are after and when it sets sand it back till it is the right shape using finer grades of sandpaper as you go. Using a cork block to hold the sandpaper is good practice too.
  • Far Canal
    Far Canal
    I'd let the painting pro do it in that case mate.
    Be nothing worse than you bogging it, painter paints it and then has you to blame for some imperfection on the final job.
  • Baloffski
    Baloffski
    Agree with FC bloodog. An accident, then repaired by a good mate, told me not to touch anything but let him bring back to standard, if not better. He would say "do what you're good at, and I'll do the same". He was one of those magicians that could panel beat, spray paint and motor build, V8 race circuit, amazing bloke.I know I love doing shit in my shed like that too, but end result is what comes mind.
