Online: speedzter
has any one used one and what is it like
  • Shambells
    Shambells
    Pro-Lift 680kg Utility / ATV Lift i am looking for comments on who has used one and their thought of the repco one please
  • binnsy
    binnsy
    Yep,
    Got one and use it regularly.  Haven't had any issues and certainly stable enough to hold a fatboy well off the floor.  Only thing i did was a little grinding on the base where the wheels are so i could get it low enough to go under the bike.  Was only minor work, just that the bike was a bit low.
  • Gnoo
    Gnoo
    The jack on the Repco one that I bought didn't last very long.
  • chopa
    chopa
    If it's not 12mths old take it back if the jack isn't working cos they have 12mths warranty.
  • chopa
    chopa
    Under Australian warranty laws you have a right to ask for a replacement ' repair or your money back
    Mines probably 10 years old now and never had a drama. Orange (of course) pro lift.
  • TJU
    TJU
    Use my lift pretty often as well but as mentioned by others the jack is starting to take a bit to get going ... is it possible to take the jack off the lift and have it looked at or better still put in a better quality one .
    Proberbly a bit of biased memories but the old jacks we had in the old Holdens and aso on seemed to last forever .
  • Shambells
    Shambells
    Thanks all for helping I am off tomorrow to get one
  • TJU
    TJU
    Got some hydraulic Jack fluid for it ... Hopefully will get it back as good as new ... Will let y'all know how it goes .
