WANTED USED Fatbob trees and tubes 49 mm dia shiny not black
Ian1955
Does anyone have a set of fatbob or wideglide 250mm between centres original or even chromed trees suit 49mm tubes they want to sell. Have a dead stock 2010 dyna supergilde and putting fatbob wheels on it. Midglide trees too skinny @ 215 between centres for the wheel hub. If you also have a pair of fatbob 49 mm tubes for sale stock or even 2" over, even better as the fatbob 3" x 16" wheel is only 26" dia vs 31" for the FXD wheel so the longer tubes might give me a bit more ground clearance.
