cam replacement wtf
cam replacement wtf
fxst
i need some advise i have a softail 2010 with 70000km and desided to replace cams tensioners plate pump push rods etc so i brought s&s cam chest kit after pulling it apart i noticed scoring on crank sharft pinion jornual more on one side than other where it goes through camplate bush is this nornal on motor with these k's. i have owned it since new and ride steady i know about murphy but still why does it fcuking happen to meeeeee all the time could it be the smoke and 47 beers cheers fxst
fxst
Yeah but what about the advice, professor
Adz69
No idea! LOL
fatslim
There will be some wear. After 70ks that's quite normal.
It will be more on one side than the other, given the pinion end is out of round on most non Timken fitted bikes, certainly after 2007 when the cranks changed.
Before the next session, round up a dial gauge, measure the crank runout, photograph and reply.
There may be nought to worry about. Sit back, relax, have a sherbet, smoke.....
NO, wait, do the dial gauge thing first okay ;-)
markwoumla
Some pics of camplate and crank from 2009 flht with 90,000 km before cam upgrade .... Crank runout was well within spec ...
Gave scoring marks a light going over with fine sand paper , (could not feel any indentations with finger nail)... You will see pic where oil pump bolts to camplate, and has more scoring marks on one side than the other ,, that is normal, due to suction operation of the oil pump .... I made decision to re use camplate ....
fxst
Thanks very much fatslim and markwoumla your info was very helpful.
I have a pinion gauge on the way to check for runout and if I can I will post some pics
Once again thanks very much.
fxst
thanks dynoharley for your feedback i'll check the crank runout hopefully its all good stick the new cams in and ride the arse off of it fxst
fxst
pinion shaft runout was just on .003 cleaned up the scoring with 1000 grit paper good as new camchest kit came with all parts needed plate pump pushrods tappets tensioners 551 easystart cams fuck what a power diffrence started straight up don't know how long i'll have my lience for once again thanks for the help and info fxst
