Online: obisteve, beaglebasher
Who in Australia can straighten a Bent Springer front end ?
  • Retroman
    Who can straighten a Bent Springer front end ? ( Don't ask ! Fucking young Indian female in a 5 series Beemer !!)
    Is there any one in Australia you could recommend as being "the man" ? In WA would be fantastic of course , but around Oz also good..
    My own bike , and I'm fairly OK with the mechanicals , but other than owning a Springer for 5+ years , I've never actually "worked" on the suspension per se.
    20Km/H rear ender is all it took , she stops DEAD in a give way feeder 2/3 over the dotted line turning left onto a dual carriageway WITH NO CUNT COMING IN EITHER LANE ???
    Bent back an inch in the old measurements, steering head bearings are fucked as well.
    No longer available as a "built unit" from HD , only as component parts ( HUNDREDS of bits , no joke !)
    You can get aftermarket "built units" of course , I know that, but they're not a straight replacement VPW tell me.
    I would fit a Crossbones fork set ( same but in all Black , no chrome , again , not available as a "built unit" )
    OR I may have to go conventional telefork front , Softail Custom/Softail Standard gear should bolt right up with minimal fuss , brakes and all
    Anyone got one of them available ? 2007 and up would work
  • keith
    keith
    Can't help on a repairer Retro, good to no rider damage. Hope you get it sorted.
  • Retroman
    Thanks mate. Broken left ring finger (Clutch lever pounded it into the bitumen). Jarred right forearm ,corked right knee. Walking wounded thankfully.
    She was most apologetic ( profusely !) for having panicked and ABS braked to a halt for no fucking reason IN A JUNCTION
    Should I have been paying better attention ? OBVIOUSLY , usually I'm all too well aware of stupidity after riding Harleys on Perth roads for 22 years.
    I rode the bike from the scene down to Frasers, I was on the way there anyways.
    Frasers don't straighten forks of course , I've had teleforks straightened many times since I started riding in 1975 , hence my quest
