Bleeding hydraulic fluid from Clutch
Ratbob
I've bled the brakes ok but finding it more difficult to get a good flow from the clutch.
A friend suggested I get a vacuum bleeder kit.
Any of you guys used and recommend one of these kits, looks like they sell for anything from $23 to $500.
(Don't think it's a blockage as the clutch works fine, just hasn't been bled for years.)
If you want the best that will last, get one of these.
http://mityvac.com.au/product/mityvac-silverline-elite-hand-pump-kit/
Mityvac silverline elite kit. $118 part number MV-8500
Its good for cars bikes etc and is a pump as well as a vacuum so you can pump fluid through not just suck it out. hope this helps. Hutch
Ratbob
Hey Adz and Hutch, thanks for the advice. Appreciated, Cheers
