Black 103 Top end with Andrews 48h cams
binnsy
Where you located?
That's a good deal
binnsy
Considering it, pardon my ignorance as a bit new to this. I have 07 fatboy will all this just bolt up or do I need to make some significant changes somewhere. The bike is stock as a rock apart from air and pipes. Just purchased a new ranger ute so dont want to outlay a heep on the bike at the mo.
Thanks.
fatslim
Top deal Murph.
To anyone thinking of upgrading their 96 ci TC, 2007 on, to 103 this probably represents the best deal seen for a long time.
Pistons and cylinders are worth say $250
Heads $300
Used cams, Andrews 48H is a very good mild cam. $150
To find all these parts together from one seller?
Gold.
Murph, you runnin' for a knighthood or something mate? ;-)
Highly recommend this bloke for packing perfectly and sending quickly, just like you'd want.
cheers,
richo
ddreed
Hi Murph83, will take the 48H cams if you separate...
