The Screamin’ Eagle® Bolt On 110 Stage III Street Performance Kit (P/N 92500035 Black Highlighted
prmeier
Thinking of adding the 110 kit to my Fat Bob. Originally couldn't decide between the Fat Bob and the Lowrider S. Went with the Fat Bob thinking I could add some performance with the dollars I saved. Has anyone installed this kit? Quoted $4300 installed from dealer. Trying to decide if I get it fitted by the dealer or do it myself. Doesn't seem that difficult. Would the dollars be better spent on cams, heads, throttle body, injectors???
dykas
My CVO Breakout 110ci with Stage 3 and VH Big Radius
spacewolf
Mate I'll sell you the 110 CVO jugs, pistons, cams, throttle body - I put the 117 kit in both the slim s and low rider s so have 2 kits. Whatever is in those kits that you can use if you want to make an offer.
Both engines had 7200 klm when swapped over, no issues - we just wanted the 117.
