Retrieving security code
chriso
Ok so been through the process to retrieve it ( ignition switch on off on off on left indicator 3 times right once) but it just ain't coming up, instead I'm getting the diag mode..
What am I doing wrong?
And no PIN IS not the VIN number and yes I have tryed joint I bought it off.
JFE
Do you have the manual Chriso? This was what the Dyna procedure is (not knowing if all are the same or not). My original code was written in there too but been long changed.
Ferrett62
Mine is different
Turn run switch to off
Turn ignition on
Cycle run switch run off run off run
Left turn twice
Right turn once
Took me twice to get it to work, youtube video says factory code is either 13131 or 31313, old age I can't remember which.
chriso
Ok got it, followed steps in my original post and changed number to my new number.
So what I've learnt is that you don't need old PIN to change the 5 digit code just need your fob.
