Brake light constantly on
BBYHD
Hey guys,
2008 XL883, brake light constantly on.
Symptoms:
1. Both globe filaments constantly on.
2. Front brake when pulled in, the rear light flickers.
3. Rear brake when pressed, nothing.
Pretty sure when I bought the bike, it failed RWC for the same (or similar issue) with the brake light, which turned out to be the foot brake switch...
Given symptom 2 and 3, leaning towards being a switch and not wiring?? Other ideas?
Thanks!
Chris
BBYHD
Update
Looks like there's a little vertical play in the front brake lever and if I apply a light pressure upwards on the lever the brake light goes out, and I can then play with the foot brake which operates the brake light correctly.
Pull the front brake lever out and re-assemble?
FXS2011
Take your foot or fingers off the brake bud!
You're welcome! :)
