Replacing Rear Light in 2013 Fat Bob
samuraidarryl
Hi all how hard is it to replace the rear light on the original shape Fat Bob? Looking at the LED light that is shaped like the fender to give it a clean look? Anyone here done the conversion? Do I have to remove the fender? Anything special to consider?
STEAMER
Should be easy enough. I replaced my FXST to a LED tail light, If I remember correctly. I had to undo the wires out of the indicator plug, but still easy. Took about hours taking my time from start to finish
