Online: speedzter
  • Ferrett62
    Ferrett62
    Trying to get some discussion going on the forum
    Just read a piece on another group so looking for opinions. This related to what revs to ride your bike at. I know I only ride above 2000 rpm as I find below that I hear the engine and drive chugging and the whole thing sounds like shaking a bucket of chains. Above that it is quite and smooth, the suggestion is that since  the 96 ci produces peak torque at 3200 rpm or so it is best to use higher-end revs or lower gear for normal riding and that is better for longevity of the motor. We all know it is easy to put around using a higher gear and low revs on big ci motors but he suggests the newer motors are rev happy and far less stressed spining between 3000 and 4000+ rpm. So just out of interest what gear do most of us use around town in traffic and when do we use 5th or 6th. This is my first Harley but being a twin cam and designed to rev higher is putting around better or using a lower gear and staying around 3500 better. It will be interesting to get opinions from all forum members.
  • keith
    keith
    5th gear 80/100,6th 100+. Around the metro seldom get into 5th. Not sure what discussion you want around the topic ? My input.
  • Daggs
    Daggs
    My bike isn't standard, it's peak torque is around 4200. so I let it rev, I don't use 6th until at least 110,  around town? Well that varies a lot but I guess mainly 3rd and a bit in 4th
  • Fey
    Fey
    Same as Keith.
  • DJP_120ci
    DJP_120ci
    No tacho so can't give rpm but my general rule is
    Cruising speeds
    3rd for 60-80
    4th for 80-100
    5th for anything over 100
    6th dosnt get a mention until around 125
    The bike seems to be happier and smoother  in the middle of the rev range (meat of the power).
    I did read somewhere that these newer engines prefer the rev a little bit and it's "better" for the engines longevity
  • Humbug
    Humbug
    School zones 2nd, 60k zones 3rd, 80k zones 4th, 100-110k zones 5th, 120-130k zones 6th.
  • Ferrett62
    Ferrett62
    This sits with what I read. Although it is not a cure the writer suggested crank slip, something there is a lot of information about in other forums, is less likely if you don't lug the motor.
    I  don't know if this is a topic of interest to all but I find it something worth understanding. We have all seen harley's rolling along at low revs and the nature of the big twin makes that easy.
    The idea is that at lower rpm with the single pin crank the drag from trying to move forward places more shock through the crank pin, at higher revs the rotational force distributes the stresses and lessens the chance of the crank slipping. In the end this means we should all ride in a lower gear or ride faster.
    I only started this thread because I noticed a lot of members logged in but little conversation going on, I thought a topic like this was  something everyone could comment on without technical knowledge, just personal experience.
  • Daggs
    Daggs
    I don't have a tacho, no real need, you can tell by what just sounds and feels right.
    I do what is happy for me and my bike. On a normal cruise I usually change into 6th over 80ks. It makes plenty of torque and is happy doing that. If i need to change down, then so be it.
    I don't need to rev it or keep it in the power range unless i'm blasting through the twisties on a mission and think i'm Mick Doohan.
    I think the lugging and chugging talk is a load of hogwash. I have had enough bikes over the years and never had a drama.
    Just my opinion and works for me. If I can't ride my bikes right after 34 years then that's my problem.
  • Ferrett62
    Ferrett62
    I agree and I ride by feel, I do have a tacho but is a digital display below the speedo and not all that readable. I only have  look once at speed, I just wondered after reading stuff about the 96 ci motors and some of the reported problems. Just got me interested how others ran their bikes.
  • Daggs
    Daggs
    Well you can see there are a couple of different styles or schools of thought and a lot of different bike set ups,  just ride it how it feels right for you
  • punkin
    punkin
    Rockers don't have tachos as standard either.
  • TheBigFella
    TheBigFella
    Have always just ridden to the feel of the bike, total contrast to work (truck driver).
    But refuse to let a motor labour, the noises coming out of a labouring engine scares me to no end,,,,,,,,,,,!
    Took me a few blasts to get used to the rev limiter on my old Super-Glide though, not so much on the RoadKing.
    But happy yo let it rev if it wants to,,,,,,,,,,,,,,,,,,,
  • OILLEAK2008
    OILLEAK2008
    Things are much more simple with my old evo - no taco, no 6th gear. Not much power or handling either for that matter!!
