Touring heel shifter question
chriso
Can anyone tell me the length of the extended heel shifters that are available.
The shifter I have at the moment is 180 mil, I presume it is standard?
chriso
Well looks like no one has extended one.
Geoff3DMN
The stock one was too short for me and I considered getting a longer one but I ended up just removing the rear lever and putting a cover cap (that HD sell) over the shaft instead. Might be an option for you?
gidgi
felt like a postie bike , took it off
chriso
Yeah that was my original plan but sort of got used to it riding back from QLD and think I want to keep one on there now if the longer one works.
Will go in to Harley today and sus it out
chriso
Well that's that settled.
Seen that linkage problem occur with a few of you blokes now.
Coming off tomorrow.
Mines never had a drama Chriso, I check it regular now though. I do have the alloy ones so this will be lighter and may not lead to an issue anyway.
graz
Stop wearing them high heels Chriso and you wont need it.
