Online: Stuart
looking for a chrome skull taillight
  • bloodog
    bloodog
    looking for a chrome / black skull taillight I have googled heaps but nothing standing out so far
    Hoping you mob can recommend it would be going onto my 09 rocker fender some thing close to fitting would do and I can do the rest
    This is a photo after removal I have the blinkers sorted just need the right tail light
    Thanks bloodog
  • mutley
    mutley
    Who needs a tail light on there when you can get this little gem made for such a purpose and even the curve of the guard, so new I had to take it out of the packet to picture it
    s
  • punkin
    punkin
    Or you could get your plate frenched in there.
  • bloodog
    bloodog
    Have decided to bog holes and spray { about $300.00 } I will leave the fender as is
    Ordered Motogadget LED M Blaze Pin Indicator Turn Signal Pair Black 8mm Mini
    Then side mounted number plate with brake and tail light
  • punkin
    punkin
    Mate i'd be spending a couple dollars and have the holes filled with weld, not bog. You could do most of it yourself even if you haven't got a welder, just give the welder a six pack and grind the metal back down yourself.
    The blinkers look great, can you tell me where you got them? I'd be looking at a chrome set to replace the cheapies on the back of mine.
  • punkin
    punkin
    Yes mate i know how to google them, i was asking where you bought yours.
  • punkin
    punkin
    Thanks.
  • bloodog
    bloodog
  • punkin
    punkin
    Aaaahhh Comes with that little resistor/diode pack? I had to make my own when i put the other LED's on.
    Good stuff.
    Unfortunately, most skulls look crap. They are cheap and nasty and have to be or they would cost too much to manufacture. Good ones are cast and cost a mint. Cheap shit is pressed and crap. It is what it is.
    Here is a good one, a crap one and a sexy one. (not in order) You be the judge.......
    Oh no, the blinkers just destroyed this one....
  • Far Canal
    Far Canal
    This one looks a bit similar but has a light in the mouth too.
    Oh yeah, headlight not tail light.
    This bike was at the Ross motorcycle show a few years ago.....I think the Grim Reaper rode it there. Got the feeling "old reaper" prolly just bought it from somewhere.
    Alternatively I guess you could just find yourself a real skull, paint it in a chrome paint, put some lights in it, and Bobs your uncle!.
  • Far Canal
    Far Canal
    Forget the skulls!
    Who wouldn't want a tail light like this on the back of the bike?
    Hell yeah!
  • bloodog
    bloodog
    you mob have totally put me off the skull tail light now
    damn....I love the idea of the small LEDs and will get a set for my bike, but they look fugly as heck just sitting out the side of the fender like that!
  • punkin
    punkin
    Mine are tucked in under the seat and the new set will replace the cheapie ones that are there. I doubt you'd see them there unless they were flashing.
