Online:
wildchild, John.R
V&H and Bassani pipes for 2004-2013 Sportster
noctm
g'day all
i have two sets of pipes for sale if anyone's interested - they suit 2004-2013 Sportsters (04-06 need O2 sensor bungs)
V&H Big Radius - $350
Bassani Firesweep - $300
$500 for both sets and im pretty firm on price as both are less than half price and $500 for both sets is like 1/4 price
pickup WA - i don't really want to post them cos posting pipes is a hassle, but if you really want them i will arrange it at your cost.
both sets have about 5000k's on them but are in pretty decent condition. they're both currently wrapped, but i have the heat-shields as well.
the big radius heat-shields have a slight dent in them where a car bumped me but it could be easily cleaned up and really isn't very noticeable - i just decided to take the heat-shields off and wrap them when this happened cos id been planning to do it anyway.
the bassani mounting bracket has snapped at the bend and needs to be welded - but its an easy fix if you can weld or a cheap job if you cant. alternatively you can modify other brackets to suit pretty easily, which is what i did. have all nuts and bolts otherwise
both sets of pipes have a slight scrape on the bottom pipe edge from leaning, but it's not visible side on and only if you look from below.
AlHD48
hi mate , hope you are alright , a car bumping into you n all
noctm
bump
price dropped as i'm running out of space in the garage
$650 for both
$400 for v&h
$350 for bassani
get yourself some good but cheap pipes for some variety at a fraction of the price
noctm
price drop
$500 for both sets which is a bargain as i would rather sell the pair.
make me an offer - i need the space
noctm
PRICE DROP
$400 for both sets.
$250 for the v&h
$200 for the bassani
