Online: B0nes, FONTANA302
Cheap Workshop Bike Lift
  • OILLEAK2008
    OILLEAK2008
    Got one of these today - $399 with a further 5% off and reasonable delivery. So far - very happy!!
    http://www.ebay.com.au/itm/NEW-T-REX-Hydraulic-Motorcycle-Lifter-Motorbike-Lift-Stand-Table-Jack-Hoist-Bike-/131355886676?hash=item1e956bc454:g:BtYAAOSw7GRZEB-7
  • Krackers60
    Krackers60
    We look forward to your ongoing review.
    What sort of bike are you putting on it?
  • John.R
    John.R
    I've got the same one, albeit different colors.
    Currently have my Evo up on it ready for some work:
    IF anyone was concerned about capacities...
  • OILLEAK2008
    OILLEAK2008
    Just an old evo on mine. Hey John.R  - is there any need to take the front side supports out wider than the first hole (mine has two) (like yours appears to be in now)????
  • John.R
    John.R
    Probably not, other then easier access. I only put those things downs when loading or unloading a bike that the table doesnt move, Otherwise they're generally back off so I can roll the table around the shed.
  • Far Canal
    Far Canal
    5 years ago
    This thread is three years old.
    Looking to get a bike lift/table and the type JohnR and Oilleak have are what I'm after.
    Wondering if you blokes are still happy with em?
    What do you do if you want to have front wheel off the lift (in the air) when it is raised?
    Any other snippets of advice about em?. They sure have gone up in price in 3 years, more than my hourly rate.
