Riser bushings - softail with Apes.
Joeli22
hi guys,
What are the best bushings I can get for an 05' heritage??
I have fitted a set of 16" carlini apes and I feel that there is a bit too much play now.
Ta j.
Go with the Silicon ones (rubber will give better vibration isolation but with the cost of more movement)
B0nes
When I changed over to 16 inch apes I fitted Urethane bushes, ordered from J&P Cycles at the same time I bought the bars. Bloody great, no movement and very little vibration through the bars
DJP_120ci
I have solid bushes from speed merchant
Might vibrate a little more then some of the other bushes people have mention but I couldn't tell you how much, I have always had solids
Joeli22
Thanks guys !
I fitted a set of urethane ones this morning and it sorted the problem, no real extra vibration issues either.
the rubber ones i took out looked like new - just don't cut the mustard with tall bars and a heavy rider.
