Screamin' Eagle T/C Performance Assist & Slip (A&S) Clutch Kit 37000026 Sealed Box
fatslim
With additional AIM Performance springs to handle further torque increases from your 110, 117 or bigger engine. Up to 145ft/lbs of torque, easily.
The springs aren't available in Australia, bought direct from AIM in the US.
This is for Hydraulic Clutch operation only, not cable. ( new Dyna is cable ) That's why I'm selling it.
I have a Barnett Scorpion for the same application if you're interested. It was used for 500ks. handles even more power and torque. Same price.
These clutches work brilliantly, unloading and taking the shock from the drivetrain to help make life easy on the crankshaft, transmission and driveline components.
This clutch kit is fitted stock to CVO 110s, Fatboy S, Slim S and all hydraulic clutch tourers from 2014 to 2016.
If you have a stock bagger and want to upgrade your engine for more power, another clutch is on the cards.
Bought the clutch as a spare, just in case. Never used, it's in a sealed box.
Retail is $545, the springs are $100 by the time they arrive here.
$400 plus postage. Weight is 8kgs, 32cm x 34cm x 14cm. From Hobart 7000 so you can work out the postage cost to you.
Ring or text: 044 triple eight 6596
The pic shown is off the HD website, the box is the real thing (in a box of course).
fatslim
Pics of the Barnett Scorpion Clutch for sale as described in the post above.
It is as new.
