PLEASE READ REGARDING SSL
Kingchops
If you've logged into the site via the secure connection:
http
s
://www.hdforums.com.au
You may have trouble logging back into the site, if you switch back to the unsecured connection:
htt
p
If you experience this issue you need to access the site via the secured connection again
and logout
https://www.hdforums.com.au
Then switch to the un-secured connection (
http://www.hdforums.com.au
) and log back in.
** If you try and switch to the unsecured connection without logging out of the secured connection first, your login won't work. **
This will be fixed in the next release.
Thanks for all the work you are doing behind the scenes KC , much appreciated .
mickle
I have deleted the shortcut to the unsecured connection and have been logging on with the secure
connection shortcut and have had no problems.
Krackers60
I've switched over to the secure site with no user problems so I that you've got it right.
Bear2009
Switched over few days ago with no problems so far
