Online: obisteve
95 cub deuce , head work flow sheets with diffent intakes
  • dynoharley
    dynoharley
    flowed heads , fitted 1.940 inlets , these heads all ready had 1.900 and head work by another eng builder , flowed with mikuni manifold on head as what was on bike ,
  • dynoharley
    dynoharley
    after flowing with its manifold , I refitted 1.940 inlets to heads ,these heads had same seat bowl bowl id , still after fitting larger valves , low to mid lift picked up nice , cut new seat angles , flowed with s/s carby manifold on after rework heres figures , before and after flow sheet ,
  • dynoharley
    dynoharley
    this was were head manifold mods and changes , now reflowed with 42 mikini carby on bench , lost 30 cfm at top
  • dynoharley
    dynoharley
    reflowed with s/s G carby on same manifold head , this is what the flow bench monitored , the final carby used on this eng build but not flowed was a 48 mikuni , its on bike now , head valve mods , better flowing inlet manifold, larger carby , netted 10 rwhp , it may not seem a lot , but it is when eng was already making very good power for 95 cubic in ,
