Online:
obisteve
Oil Change for 1200 Sportster Conversion
ScreaminSmeagle
Looking to pick your brains for some garage tricks.
LDoing an oil change and primary/tranny oil change on my 2004 Sportster that has a 1200 conversion.
Does the conversion call for a different spec oil? and is there anything you would add to this 'How To': https://www.ifixit.com/Guide/Harley-Davidson+Sportster+Evolution+Oil+Change/6211
Cheers chaps.
Kingchops
You don't need a separate oil for a 1200, same oil as 883. That oil change guide seems good but it only covers Engine oil change. The primary oil change is a separate process. Primary fluid is different to engine oil. Do a search you should be able to find a good guide for doing the primary fluid change.
AlHD48
recommended by eastern big twin for my sportster 48
primary transoil expert SAE 10w40 - motul
twin syn 20w 50 - motul
these two are the best i have used
For my 2009 883
Harley 20/50 for the engine
Redline transmission oil for the primary/gearbox - fantastic stuff for clutchless shifting; which I do about 80% of the time (gotta use the right Redline for a sporty as the one for Big Twin tranny's has additives that do not go well with a sporty clutch)
Thats the one the Redline MTL for Sportsters and Redline Shockproof in Big Twin Trannys.
OILLEAK2008
From what I have seen on the Net, this thread was a tame one. Usually when someone ask's a question like - 'what oil is best for my Harley' random fist fights start, divorces happen, dogs bark and the host site goes into meltdown.
