sissy bar
sissy bar
Shambells
hi all just wondering has anybody moved there sissy bar back couple of inches.
i have a 2004 super glide with fixed rails for the sissy bar and my problem is
there is not much room for the wife to get on. do they make a relocating kit for the
sissy bar of do i have to weld some extra pate at the front of the rail and re drill
the holes.
please help.
Krackers60
No much happening for you here at all Shambells.
Have you come up with a solution?
Shambells
no not yet i will ring hd in bundaberg to see if they have relocation brackets. there must be a lot of people in my situation
Sugar
Had the same problem with my breakout. A little modification and all is good.
Sugar
Added some 3mm plate to the sides so the bar itself is 30mm back and 40mm higher and welded it. Not very showy but does the job.
