Mini electric tyre pump/compressor recommendations 12v/240v?
Kingchops
I've been looking for a good electric tyre pump for use at home. I've got three motor vehicles and six push bikes which all need tyres inflated from time to time. All I've currently got is crappy 12v mini compressor that over heats after a minute or two. I have to power it using a battery charger which is annoying. For the pushies I use a manual bike pump, but with that many pushies it's a lot of work.
I need an electric pump that I can power from 240v, would be nice to have 12v option as well. It must be reasonably small. I used to have a full on compressor which was great but too much work getting it out for just tryres. Also, it must be able to do a decent amount of work, unlike the crappy one I've got now. What do people recommend?
I've been looking at this cordless unit below, it looks good, but not sure it would be powerful enough. Cordless would be good but I'm concerned they'd run out of juice after a couple of tyres:
http://www.ebay.com.au/itm/281268501687?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
imoo6170
Harley does one which connects to the battery trickle charger connection - seems a reasonable price .. https://shop.frasermotorcycles.com.au/products/harley-davidson-compact-air-compressor-with-light-12700020
Sorry just saw u wanted 240 volt ....
If price is not an issue, and you want a decent unit ( edit : maybe not so decent after reading reviews !) , I would look at something like this :
http://www.supercheapauto.com.au/Product/Stanley-Wall-Mount-Air-Compressor-0-5HP-14LPM/342509?menuFrom=1021507
The other option is to buy a heavy duty 4wd style 12v compressor and use a 12v jump starter pack, or a used bike battery !
Any good quality unit won't be cheap.
Bugger, I was hoping for some clear recommendations on this one too. I'd like a good pump for home, but I want something that's accurate.
Geoff3DMN
I've got an Ironman 4x4 tyre compressor that I use for my dual cab ute and for the bikes.
It does draw a fair bit of current when running so you need a decent power source to run it, I plug mine into the anderson plug in my ute tub when I want to use it.
Mine will pump 4 32 inch 4 wheel drive tyres from 18psi to 32psi in about 15 minutes, it gets hot but it never activates the over heat cut out (and yes it has one).
http://www.ironman4x4.com/category-products/air-compressors
Geoff3DMN
I paid about $170 (for the lower volume one).
The faster one would be more (haven't tried that one only the cheaper, slower one to the left on the web page).
Far Canal
I reckon a fair dinkum 240 volt compressor that'll do 12CFM+ is hard to beat.
They are just so handy. Pump up any tyres, clean shit outa anything, even with a bit of practice and a reasonable spray gun you can paint like a pro.
A must for the home workshop.
Y'outa be able to find a second hand one easy enough.
If your interested I attached the Choice review on them.
Soapbox2627
Aldi has a compressor on sale this week
robnicko
https://www.bunnings.com.au/ozito-12v-240v-dual-power-inflator_p6290556
...del
Kingchops
Ended up buying this unit from that well known hardware store:
https://www.bunnings.com.au/ozito-1100w-inflate-it-compressor-kit_p6290319
After trying it out, it's great. For a relatively cheap unit it's fairly well built. Has a decent sized air hose, with a proper air tool connector. Comes with a tyre inflation tool with gauge and some other useful air attachments. Delivers a decent amount of air and is 240v only, but that's mainly what I need. It's pretty loud and noise is continuous when turned on but aside from that it does the job well. The shape of it is good, just right for putting against a garage wall without taking up much space. Warranty is good too 3 years.
Big Steve
Looking at this one for me.
https://www.adventuremoto.com.au/cp-exp-straight-bestrest-cycle-pump-expedition-with-straight-chuck
© 2025, v3.1.0
