Online: Retroman
Issues With Clutch Adjustment
  • JustinCase
    JustinCase
    1981 FXEF
    Hey Guys,
    Hoping someone can offer up some assistance with a clutch issue. I just replaced the clutch cable, the old one had the outer sleeve shrinking away from the end of the cable up at the bars. I figured that that wasn't going to get any better.
    Bought a replacement from HD Dev in Melb. I noticed quite some difference in cable diam plus the fittings appeared more robust.
    So I r & r the cable with nil issues however when it came to doing an adjustment at the clutch release lever their was no way I could get the gap at 20mm, which is the recommended gap out of my Clymer manual. I released the clutch push rod and then attempted to do the gap mentioned above but the best I could do was about 8mm or so.
    Bike is still on the c/stand, haven't ridden it yet.
    The old girl would usually 'walk/creep' in first gear but only when it was cold. It's done that since I've owned it. I never saw it as an issue.
    I have a 5 bolt clutch hub put on by the PO.
    Any ideas would be greatly appreciated.
  • JustinCase
    JustinCase
    Thanks Dave, I appreciate your response. Looks like I'm getting a Ram Jet. Install seems doable even for me.
    Re new clutch cable length: I actually bought a stock length one, however I have 3" risers which have resulted in the cable being just long enough.
    I'm thinking maybe I should of got one about 2' longer.
