Online: Retroman
code on odometer motor cutting out
  • wildhog55
    wildhog55
    i have a 2016 roadglide speacial , converted to a trike ill try and put a pick up code keeps coming up when the meter cuts out upside downF normal I AND P
     FIP AS DISCRIBED ABOVE  PLEASE GIVE ME SOME HELP , MAINY HAPPENS WHEN TURNING LEFT HARD?
    pat
    It's the bank angle sensor in the tssm.
    The bank angle sensor is a safety feature that cuts off power to the engine if it leans over 45 degrees,
    it thinks the bike is on it's side.
    It's supposed to be disabled in a trike, take it back to whoever did the conversation, they should have disabled back then.
  • JFE
    JFE
    If you can get it disabled, that would make sense. I actually had the same issue with my 2015 Fat Bob and the ecm was replaced under warranty -- faulty, no explanation given and no hassles since.
    Not fun when the bike runs out of go unexpectedly.
  • Sparra
    Sparra
    Thanks mate,that makes sense...
  • wildhog55
    wildhog55
    Thanks guys that gives me some heads up first time user here , and a bit of a dinasor so thanks all, hope its the sensor and not the ecu
    pat
