Pots & pistons
Pots & pistons
srd0060
Good afternoon, Can I just change the pots and pistons on my 883 to 1200 or do I need to change cams as well?
brash
Google hammer performance
What these have the sportster performance game wrapped up.
Daggs
Yes you may not "have to" but a cam change set with matching compression and a decent tune would be the go while you are doing work anyway
srd0060
Thanks guys, i will look into it, bigger bike or bigger engine upgrade..
Daggs
Moving up to a big twin might be the go
