95 cub build , came in made 67 rwhp , when out went 106 rwhp ,
dynoharley
Adam76
Nice work Dynoharley. Pretty strong for a 95" build.
What exhaust was he running - can't tell from the picture.
Adam76
Thanks mate. Will do. Cheers
punkin
Whats a ball park figure if a guy wanted to do something along those lines....how much money should he have in his pocket before he starts talking to people?
TD302
Any specs you can give out on the combo? I have a 95" making 111 and 113 keen to see what other setups run.
punkin
Thanks mate, good to know. Makes a crate engine sound semi reasonable.
Need to consider that crate engine doesn't include worked heads, manifold, ignition system, exhaust etc
Sounds like dyno Harley's price is a complete turn key job. Drop bike off and pick it up later with all parts, labour, run in and tuning done.
Good result.
punkin
I probably put that wrong, i would much rather keep my engine in my bike, plus i already have pipes, tuner, airfilter etc which i'm assuming would save me 1.5-2k.
Merely noting the relationship between the prices, and as far as i can tell, the relationship is in favour of stock, worked engine. Especially in my circumstances.
graeme
I had 95 kit hi comp pistons,new heads ,mikuni,211 cams ,cam and oil pump upgrade,decompression buttons all up $6000 from Geelong Harley 6 years ago done another 40k still going good around 100 x100 dynoed by lushy
graeme
I'll try and find Dyno sheet and see if I can load them up
