Tyre Fitment
  • Sparra
    Sparra
    Just wondering if anyone can tell me if a 17"rim that normally takes a 160x70 will also accept a 180x60??
    Cheers...
  • Sparra
    Sparra
    Hey Pauly...I am just about to order a new rear tyre for my wideglide that normally has a 180x60 rear tyre but I have a switchback wheel on it that takes a 160x70 and was just going to go back to original tyre size,mainly for looks as long as there are no safety issues...I want to keep the switchback wheel as I am not a fan of spokes...
    Cheers..
  • Sparra
    Sparra
    Thanks mate...Looks like they are the same size rims so all good..
    Cheers...
    It was a reasonable question!
  • Sparra
    Sparra
    Can anyone tell me what the difference is between these 2 tyres.
    180/60 B 17 M/C 81H REINF
    180/60 B 17 M/C 75V TL
    Cheers...
  • Sparra
    Sparra
    Thanks for that...So in reality you would add bike weight+rider weight+ gear weight,divide by 2 and that would give you your tyre load capacity..??
  • Sparra
    Sparra
    Thanks Geoff...i have a tyre ordered the same spec's as standard so hopefully all will be good..
    Cheers...
