Twin cam engines
Twin cam engines
AlHD48
Hi all
Does anyone know if hd if still using platic parts on the chain cam ?
Anyone had a engine fail with this problem ?
AJ56
I changed out my tensioner shoes after 100k, front was shot to shit but the back was still good. Nylon and Teflon shoes are used on the tensioner assembly but you have to buy the whole assembly in Aust, you can get just the shoes of Amazon/ US sites for 1/4 of the price. If you go down that road change out your inner cam bearings as well for Torringtons.
AlHD48
Hi aj . How much did it cost? .i heard you can change to a belt driven cam instead of chain and you won't have that issue anymore,
Has anyone done this and whats the cost ?
AlHD48
Hi pauly . Fixed up the post. I should have proof read it
brash
I'm guessing you mean gear driven cams?
They work well, crank runout has to be within spec of .003 off the top of my head to run one.
They are also expensive when compared to chain driven.
http://www.woodcarbs.com/bdrive.htm
AJ56
http://www.hdforums.com.au/Thread/653976/2/. Answers any questions you may have.
I think the first twin cams, had a few design problems, HD made a few changes over the years to improve.
also if the motors left bone stock, like stock cam's stock valve springs. I think the adjusters will last longer. as heaver spring pressure would put more load on cam chain and adjusters. the first twin cams came with old style valve springs, but new ones have beehive springs so less valve seat pressure they also use 7mm valve stems so valve train lighter. i had a tuned up 88 TC & every 20k had to change tentioners, then soon after a tentioner change the new tentioner fell apart, was the outside tentioner, got lucy got it with all parts still in cam chest not mown in crank case. so i bit bullit went gear drive kept same cam grind ( just s&s gear drive ) at the time there was some wild claims that going gear drive gave an extra 6HP. i had andrews 55 cams chain drive, picked up near new used gear drive andrews 55 cams from friend in USA. you need to change cams when you go to gear drive as with chain cams rotate opposite way as gear drive but thats only difference if you keep same grind cams. I found there was not even one HP in it, was the same. but the gears & the cams still in the bike 100,000k ? (mate owns bike now ) just the crank pin slipped and crank went out of Coppoling took the crank end oil pump with it but gear drive was ok, was just lucky as did not ride it far when crank pin slipped or would have taken the gear drive out too. got a used near new crank had pin spot welded so gears spot welled stock 88" stroke made a strong motor!! just more trouble than most would go to.
you hear people knock twin cam's & say EVO the best. well i have seen three EVO crank pin's break in half.
AlHD48
Thanks for the info guys
I only heard about this not to long ago , and was wondering what the go was .
