Oil coming out of the air intake?
Rod 48
Hi, someone could tell me why the oil was coming out of the air intake. This happens more often when I ride at high speeds. I already checked the level of oil and it is at the correct level. I have V&H FP3 and it is set correctly. Thanks
Bear2009
I had this same issue on my 48 when I changed the air cleaner and oiled the K & N air cleaner too much . , when it gets hot spat the oil all over the exhaust and bike , might be your issue , clean the filter and oil again lightly only needs a little on top of each fin
srd0060
It will happen if you put to much oil in the oil tank.
