Online:
Hilly
breakout 110 kit
breakout 110 kit
MNTL1
Hi Guys,
I am looking at doing a 110 build on my breakout using either the s&s or HD bolt in cylinders.
other specs
fueling race camplate
fueling race lifters
fueling oil pump
s&s pushrods
s&s 635HO Cams set at static 10.2:1
what are peoples opinion on this cam and running it at this comp my ccp will be around 193 and corrected comp 9.28:1 is this comp too high to work on 98 pump fuel
What are you doing re heads?
Gonna use roller rockers?
MNTL1
I'll be getting my heads cnc ported I'm still undecided on roller rockers would you recommend doing them with a cam of this lift
Chaser
I spoke to my mechanic about this recently. He has done a heap of these mods before and couldn't really care less what I decided but did say the original HD cylinders have very thin walls whereas the S&S are a better make and thickness. Something worth checking out.
I'm no expert but when talking past builds and plans with assorted shops, roller rockers were often recommended with lift over 600.
