Online: Humbug, Hilly
2016 Street bob mini ape height
  • dyna matt
    dyna matt
    i have a new SB and im looking at going over to the frisco style/wild1 outlawz bars. i was thinkin 10 or 12 inch. One shop said a 12 wouldnt fit, but from my rough measurements, theyre a 12" from factory. Can anyone confirm the standard bar height?
    Matt
  • Daggs
    Daggs
    10"  12" will fit fine, standard wiring will be long enough but cables may need re-routing or at worst a longer brake or clutch lines
  • dyna matt
    dyna matt
    I had a measure the other night, was looking more like 12 inches. Was told the older model was 10 but the newer is 12.
  • Daggs
    Daggs
    Yes my stock ones were 10" but if you have measured yours and they are 12" what is your question? ??
  • dyna matt
    dyna matt
    Nah I asked the other day while trying to buy bars at work. Bike wasnt with me so .no question now
  • swilko9
    swilko9
    I fit a set of 14" Burleigh Highbalss with 1"riser and did not need to change the cables.
  • Damo14
    Damo14
    I had a set of 12 DNA Monster apes with stock cables, no issues.
  • dyna matt
    dyna matt
    All good lads. Got sorted with a set of 12 inch wild1 outlawz.
    Fit nicely.
