Online:
John.R, Hilly
Replacing wideglide battery
WideglidingNZ
As the title states I need to replace my battery on my '15 wideglide, I pulled the old one out yesterday and the alarm went off for about 20 minutes then stopped, what do I need to do when I fit a new one tomorrow, cheers
WideglidingNZ
Ok I can answer my own question now- to remove battery 1/ turn ignition on, 2/ remove main fuse 3/ remove battery, then do the opposite to replace, pretty simple once you know, apologies for asking such a simple question
Sparra
No need to apologise,there are probably plenty of people on here that don't know how to do it as well..My wideglide doesn't have an alarm so mine is an easy change over..
FatboyMac
Found this on the USA forum......'My siren used to chirp 2 times when I turned the ignition off. Now it chirps 3 times, which the service manual tells me the internal battery may be dying or dead.'
