Online: FONTANA302, Merv
Broken pinch bolt
  • fathee01
    fathee01
    Gday all , i have a pinch bolt that has snapped leaving the threaded part in place, as I don`t have access to a welder I am looking for another way to remove it. Any tricks ?
  • Daggs
    Daggs
    Drill and easy-out
  • Ando
    Ando
    Small centre punch and see if you can screw it out should have no weight on it now you have snapped it
    spray with CRC or the like
  • brucefxdl
    brucefxdl
    left hand drills work well.recently did my head stem bearings and replaced the 4 bolts at about $1.50 from dealer.peace of mind with 4 new bolts at correct torque.cheers
    +1 left hand cobalt drills. best item to get loose studs/bolts out quickly that have broken.
  • fathee01
    fathee01
    Cheers to all , cobalt drill + no pressure= no hassle getting it out.
