'16 Street bob, which indicator relocation?
  • dyna matt
    dyna matt
    So my plan is to fit a detachable sissy bar and rack on the street bob, but of course the indicators are in the way. Looked into the great bike gear setup but with our dollar its almost $400.
    Harley put me onto this kit
    http://accessories.harley-davidson.eu/product/67800499/docking-hardware-turn-signal-relocation-kit
    Which is not bad at $145 delivered, apart from the fact that a little bit of the cable will be external to the fender, hardly what i want or expect on a bike that cost up over 20k
    any other ideas, photos or advice would be awesome,
    Matt
  • petebob
    petebob
    Where will the cable be external?
  • dyna matt
    dyna matt
    apparently below the fender strut. something to do with the turn signal/stop/tail combo setup. i dont have the rear tail light like you have and the cable diameter causes an issue, or so the dealer has said.
  • petebob
    petebob
    Wow. That does sound dodgy. Sorry. I didnt even consider there would be a reason why the wiring wouldnt pass through the centre of the stalks/docking points as they do on the stock ones.
    Maybe check another dealer. The link you posted is for Europe. Maybe thats the issue??
  • robots
    robots
    Could be to many wires to cut and join,
    Maybe trace back to ecm and unplug there
  • dyna matt
    dyna matt
    i think its do do with coming out inside the fender and clearance issues. the new model doesnt have a fender strut cover aswell. tried multiple dealers, only posted the European link because the US site wont show the number due to it being a different light setup again. id rather not move them back to the number plate. thought harley wouldve made it a bt easier considering a large amount of people like the detachable setup on these bikes.
