Online: Soapbox2627
odometer numbers playing up. 98 fatboy
  • beehappier
    beehappier
    I have got a 98 fatboy and recently the numbers on the odometer have been playing up a bit.
    It says 66666 instead of 88888 when I turn the ignition on and while I am riding around parts of the numbers on the odometer are playing up.
    I looked at connections and traced the problem to the white box that sticks out of the back of the speedo that the cable plugs into.
    It turns out that if I give the white box a bit of a wiggle, the rest of the numbers come back. If I press the white box into the speedo  the numbers are fixed.
    I tried clamping it up and siliconing it together but it didn't last long. I'm pondering the idea of superglue but before I try something I can't undo I figured it was time to find out if anyone else has fixed a similar problem. The last option is a new speedo. But I'm hoping it doesn't come to that.
    Thanks.
  • fathee01
    fathee01
    Looks like super glue might be in order as everyone seems stumped.
