08 FLHT electrical problem.
  • Neale
    Neale
    Hello all. I have an issue with my charging system. I was riding today when I noticed that my speedo needle went back to zero, and came back on after a few minutes. The engine fault light came on and disappeared, and my voltmeter tells me that it's pulling over 16 volts, the needle is at the upper-end of the gauge. The bike will not idle now. It konks out immediately when I let go of the throttle. Something that it's never done. Any suggestions appreciated folks.
  • markwoumla
    markwoumla
    There are a few tests you could do to test the system ,, but this straight away points to a bad regulator ... High voltage , (as you seem to have), can play havoc with all sorts of electronics , (as you also seem to have)... First off,, check cables and connections to regulator ,(your reg is earthed to the frame , check that connection also),,,,
    Get a digital Voltmeter ,,, Place Voltmeter across battery terminals and leave it there for this test ...... (what is the voltage ? ),,,,,, Start bike, (what is the lowest voltage at start up ? ),,,,,, At idle , (what is the voltage? ) ,,,,, At 2000 rpm,(what is the voltage ?) ,,,,,,,, Now the big test ,,,, what is the voltage at 3000 rpm ? ,,,,,, If voltage is above 15 volts at 3000 rpm , (or any time),, your regulator is bad ......
    As you fairing voltmeter, (which is a reasonable indicator),, is showing 16 + volts ,, the digital voltmeter will tell the real story .......
  • Neale
    Neale
    Thank you sir. Appreciated.
    Another consideration is a faulty speed sensor which can make your speedo go back to zero, cause idle/stall issues and throw a fault code. Need to check what fault code you got. Not to say that mark isn't right either
  • Neale
    Neale
    Thanks fatbat.
  • markwoumla
    markwoumla
    Neale ,,,, Seems like you may have had success with your fault finding efforts ,,,, After your fault finding ,, what was the problem ???
  • Neale
    Neale
    HH at Blacktown rang to say my new voltage regulator has arrived, I will pick it up Saturday. I will let you know.
  • Neale
    Neale
    Problem solved. $335 later. Thanks for the helpful advice, appreciated.
  • steelo
    steelo
    Nicely diagnosed MW. smiley
