Online: Humbug, speedzter, Merv
Need some help or advice
  • 4emmalah
    4emmalah
    hi all i need to relocate my rear no plate(vic roads)
    i cannot get a rwc with side mount
    i have a heartland 280 rear end
    with a short rear guard with lcd lights
    i would like to mount it on the fender flush if allowed or however ican your advice and help would be appreciated
  • Far Canal
    Far Canal
    Obvious place to mount the plate is smack bang in the middle of the rear mudguard just above the led's. Or whatever those white dots are where the mudguard ends.
    Ask a simple question,
  • 4emmalah
    4emmalah
    would flush mount be legal
  • punkin
    punkin
    The cameras wouldn't be able to see it if flush mounted there. I would think that making a temporary bracket to hang it below the mudguard for inspection and then moving it back to the side location would be your best bet.
    I have mine flush mounted but the guard is longer than yours by a long shot.
  • bloodog
    bloodog
    Ring your rego depo and ask for the rules....then work with that, if the twisters pull you over, then you can tell them.
    I have just asked my local rego for my rocker and side plate is Ok in the NT
    Very nice ass end on your rocker there bro
  • FXST11
    FXST11
    I believe the ADR is 45% angle from ALL Deirections, So laying flush/Flat at a guess I would say not.
  • me_ashman
    me_ashman
    Just make a temp bracket to fit the back in the centre...after you get rwc change it back.
