DBW throttle "sticky": Any clues ?
  • Retroman
    2013 CVO Breakout , the DBW throttle is "sticky" , just developed today. 16,000 k's on the bike.
    Bike will rev to 3K+ if you dip'pop the clutch without pushing the throttle back.
    Seems to have lost the " snap-back" , but not all the time !
    In the past I have lubed and adjusted Harley throttle cables many ,many times and cured sticky throttle quite easily.
    Anyone on the forum had similar isues with a DBW throttle ?
    And if so what was the "cure" ?
    I've seen the problem on various Youtube videos , but no "cure" other than "new replacement" !
    That I'm trying to avoid on a 16,000K's bike if I can.
    I have not opened and looked as yet , a tomorrow job when I gets a minute
  • Retroman
    Well I may have answered my own question , got into it this evening.
    Removed the top of the right hand switchgear and wiped out the top half , and used "3 in 1 Silicone Garage door lubricant".
    Sprayed this carefully down inside the throttle grip as well , and carefully reassembled. Snap-back now perfect
    Seems all good now , a 6 K's test ride saw no dramas.
    May have been grit/sand , but I did not see it ! Or just a combo of too many dry surfaces rubbing.
    I'll post again in a few days with a definitive opinion
