Front Caliper moves
  • mutley
    mutley
    OK guys this is the one to think about after putting a new tyre on the front of a heritage springer i just noticed that the front caliper thats in front of the downbar on these is moving a little  in and out as the wheel moves, now i have never realy noticed this before but to be honest never looked for it either, the brake does not pulse as a warped disc would make happen and the brake works fine, anyone got any ideas or knowledge towards this???
    thanks guys  smut
  • Adrian1200CA
    Adrian1200CA
    Disc is warped or got bent when the front tyre was changed. Get a big Adjustable spanner, rotate the wheel find the start and finish and bend it back gently. Could also be your bearings need changing if wheel moves the same as disc.
  • mutley
    mutley
    Did the bearings while wheel was off
