Ohlins HD 159 rear shocks
mickle
You will still scrape your pipes trying to get away.
Steve L
good buying and decent shocks really make a big difference on the tourers.
Are they fitted with the standard springs (listed as 25N/mm ) ?
Tempted to try them on my FXDX.
Strangely enough the Ohlins FXD shocks are listed as having a heavier 32N/mm spring.
Actually a little too short !
Stock FXDX adjustable showa's are 340mm, but no problems now anyway
Steve L
did they sell
