Can not put code in Red Key
  • bloodog
    bloodog
    Have search every were but finding no joy
    0/9 rocker just removed bars and rerun wires through bars, now can not get secturity code into systom.The  speedo lights up with odometer reading and red key flashing I tryed all the on off on off blinkers 3 times crap but not a thing?
    I have also just removed the right side indicator and just taped up the wire ends .....This maybe the problem
    The dash lights up and the back indicators blink on there own, head light comes on, but every thing else is dead. The wireing has been put back correctly { well Im very sure }
    I will ring hog shop tomorow and ask .... any help cheers
  • Sparra
    Sparra
    I know it's obvious but have you checked the fuses..I changed bars a few years ago and something similar happened..After pulling all the wiring out and checking it I checked the fuses and one was blown.My bike doesn't have an alarm but it pays to check the easy things first..
    Cheers...
  • bloodog
    bloodog
    All fuses are good
  • bloodog
    bloodog
    Got it ......and proud of my self, I left the bike for a few days then went back over what I had done looked and thought about it.
    The conectors with the pins when I put them back in I had not pushed the pins through all the way, about an extra 15mm more. They were not making contact when closed together......
    Common sense, patience, VB
